I am looking at buying a used ECU to put a tune on. Question is, other than the part number 211175-,does the last four numbers indicate anything other than the year or model? I have a 2022 and there are not a lot of used parts for them out there.
Created on: 06/28/22 01:26 PM
M3GUNR
#21175-????
06/28/22 1:26 PM
siroht
RE: #21175-????
06/28/22 2:49 PM
I know for the 2012 and I'm pretty sure it's the same for your 2022 that the ECU serial number scheme is broken down like this:
EU/Australia ECU example 21175-1115
USA/Canada ECU example 21175-1128
21175 indicates the manufacturer, which in this case 21175 is allocated to Kawasaki ECUs.
The next set of 4 numbers are region codes, which in the above examples are for EU/Australia and USA/Canada.
So when buying a ECU make sure it's for the correct region for which your bike was made for.
Here's a list of ECU serial numbers for 2022 14R's where I in bold are all USA/Canada ECU part numbers.
ECU Part Numbers:
21175-1123 FG1773D
21175-1123 TG1773C
21175-1124 FG1774C
21175-1124 FG1774D
21175-1124 TG1774B
21175-1125 FG1775C
21175-1125 FG1775D
21175-1125 TG1775B
21175-1137 FG1776B
21175-1137 FG1776C
21175-1137 TG1776A
21175-1149 FG1779B
21175-1149 TG1779A
21175-1160 TG1780A
Hope this helps.
* Last updated by: siroht on 6/28/2022 @ 2:58 PM *
siroht
RE: #21175-????
06/28/22 3:05 PM
...forgot to add.
The last set of numbers/letters is the ECU BIN File serial number that's stored inside the ECU and can only be extracted until or unless you can READ/DUMP the ECU file with a tool such as Woolich Racing.
M3GUNR
